Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > RC Fuels
Reload this Page >
types of fuels claims on o%nitro??
RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Old 12-28-2004, 12:16 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Default types of fuels claims on o%nitro??
what is the difference of no nitro like tower sells and your cool power that tower sells with the nitro 0% or 4% % content?Im looking for the lowest % that will still fly my sport modles and cubs and I dont get it how they say the performance is great even with the FAI 0% fuel without nitro? anyone have the answer?
Old 12-28-2004, 03:58 PM
jaka
Default RE: types of fuels claims on o%nitro??
Hi!
Well some engines will work just fine on 0% nitro. Like all Webra and MVVS engines.
This is the way they are made (their combustion chamber is smaller, which mean they have higher compression, that way they don't need lots of nitro).
Nitro in just small quantities like 5% will make most engines run more reliable (have better idle and response and is easier to needle).
Regards!
Jan K
Sweden
Old 12-28-2004, 10:38 PM
suzonka
My Feedback: (7)
suzonka's Avatar
Thanks Jaka ,I often wondered how they made good claims about 0%
Old 12-28-2004, 11:51 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Add Moki engines to the list. They run the best on 0% nitro.
Old 12-29-2004, 01:39 AM
suzonka
My Feedback: (7)
suzonka's Avatar
thanks again , so OS engines need some nitro
Old 12-29-2004, 08:54 AM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
yep, 5-10% is fine
ORIGINAL: suzonka
Old 12-29-2004, 09:00 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Add Fox engines to that list of 0% nitro engines.
Old 12-29-2004, 10:02 AM
downunder
downunder's Avatar
Surprise, surprise All engines will run just fine on zero nitro, including OS.
Old 12-29-2004, 10:42 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Down, all I use in them is Fox 5% nitro fuel with 20% 50/50 lube.
Old 12-29-2004, 03:43 PM
suzonka
My Feedback: (7)
suzonka's Avatar
what is the right info, only some engines or all?
Old 12-29-2004, 03:50 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Some were actually designed to run on 0% nitro. Many are listed above and are European designed. Irvine is another one that needs very little niro.
Now take YS or Saito engines. Many people use 30% heli on some of those engines. That gets expensive. Try running a YS on 0% nitro and you will not be happy with the results. 20/20 is the norm on those engines.
ORIGINAL: suzonka
Old 12-29-2004, 03:52 PM
PhilNZ
PhilNZ's Avatar
Hi,
I disagree with this general statement ..
No " all " engines will not run ok with NO NITRO..
If you read the manufactures recommendations on what fuel you should run you will see that each manufacturer will state something like 0 % Nitro 20% Oil ( 30% castor / 70% Synthetic ) or all castor plus 80% methanol.
FAI fuel is 20% oil 80% Methanol ..
Some manufacturers may state 5% or up to 10 / 15 % Nitro it is usually on the manual that comes with the engine or on their website..
The best way to find out is ask your engine supplier or go to the OS forum @ RCUNIVERSE ask the people that make them as it will be them that replaces it if it bombs out under warranty and if you have been running the wrong fuel then your warranty maybe no good.
Regards
Phillip
ORIGINAL: downunder
Old 12-29-2004, 04:12 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
One thing is certain, they will not bomb out from using 0% or 5% nitro. They may run a couple of hundred rpm shy on top end but that is all.
Old 12-29-2004, 04:29 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
Now this is one statement that I'm sure is backed up by experience. How many engines do you have now? The last number I heard from you was around 140?
ORIGINAL: hobbsy
Old 12-29-2004, 04:58 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Actually Joe, the last engine I bought is a Conley 120 and it is #120 and I think I have my Zenoah G45 sold so I'll be down to 119. I have spoken for the first Saito 2.20 my LHS gets, qualified by if and when, and I have a Fox .50 coming any day now. Taking about the 5% nitro and engines, it works just fine in my OS LA .46 and .65. Big Saitos run great on 5% nitro also, the little ones don't do as well. I accidently put 10% nitro fuel in my MDS 2.18 at W8YE's house summer before last and knew instantly something was wrong. It made real unhappy sounds.
Old 12-29-2004, 06:17 PM
downunder
downunder's Avatar
Ah OK..maybe I was generalising too much when I said ALL engines will run fine on zero nitro. If I was using an .049 then I'd use nitro. As for reading the manufacturer's recommendations, they know that a bit of nitro will make their engines easier to start and tune for the beginner but that doesn't mean it needs nitro.
As hobbsy said, they will not bomb out from using zero nitro, it's the oil (type and quantity) that determines how long they'll last. I've always said that if you really need the extra few hundred revs you can get with nitro then you need a bigger engine and have better fuel consumption as well.
Old 12-29-2004, 10:37 PM
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
120? That's plenty. I can see why you like collecting them, they are neat little machines. Especially the 4-stroke radials. Ok back on topic. So your MDS 2.18 wanted 0% nitro? Like the Moki's?
ORIGINAL: hobbsy
Old 12-30-2004, 08:00 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I'm sure it would run fine on 0%, I've never had anything but 5% but it does well on it using a Hangar 9 HAN3006 SuperPlug. It sure didn't like the 10% though.
Old 12-30-2004, 10:13 AM
suzonka
My Feedback: (7)
suzonka's Avatar
Well this all settles up my question what 0% is good for, it sounds like anything smaller than a .049 and anything half worn out and anything with low compression just DON'T LIKE IT Bottom line, Thanks guys,Ill have to try it , I'm pretty safe with my 1 yr old Magnum BB 46.
Old 02-14-2005, 08:54 AM
speedster 1919
speedster 1919's Avatar
Remember FAI is pure castor oil content since it is availible in every country in the world. 0-5% nitro and oil blend would be fine.
Old 02-14-2005, 07:08 PM
RC-Captain
RC-Captain's Avatar
The longer I'm in this hobby the more I realize that I DON'T KNOW JACK!!!
LMAO sometimes I feel the same way until I get bombarded with queston when I am at the field.
Old 12-30-2005, 10:54 PM
estradajae
I have been running my .46FX for 3 years with no nitro..ENgine runs great!
Old 12-30-2005, 11:16 PM
B.L.E.
B.L.E.'s Avatar
I once tried FAI fuel in a Cox .049 and yes, it started an ran just fine. It was a little down on power but it did run.
Old 12-31-2005, 05:35 AM
suzonka
My Feedback: (7)
suzonka's Avatar
ORIGINAL: B.L.E.
Thanks for the answer
Old 01-01-2006, 01:31 PM
estradajae
and my engines start instantly without nitro...
