Rc Fuel Faq
#301
IN
RE: Rc Fuel Faq
airplane fuel in duratrax RT-X27: have now burned 4 gallons of the wildcat 15% nitro airplane fuel without any noticeable problems. The 4.4 supertiger still has plenty of compression starts and runs great no mater what the Lhs says and I bought another truck for my wife and run the same fuel engines can be heard in this short video clip http://www.youtube.com/user/hunterna.../0/8hpiyU54QT8
#302
RE: Rc Fuel Faq
Please please, i have been strugling since the last 5 months
I bought this HSP Gladiator used from a friend he said it worked fine last time he used it
I traied running it many many times , it is still in a new condition as it was only used 3-5 times
I found out that if i put fuel into the the engine it runs fine then when the fuel runs out after 5 seconds it turns off
The fuel is not going through the pipe,
Please have a look at the pictures i made
Here:
http://tinypic.com/view.php?pic=2lw7tz4&s=6
And
http://tinypic.com/view.php?pic=13z7h9l&s=6
Sorry about the low quality its my phone : )
I hoe i get a reply ASAP as im going on a trip on Friday
#305
WI
RE: Rc Fuel Faq
You need to figure out why fuel is not flowing to the engine. Is it blocked somehow? Is there dirt in the line, or a kink in the line? Does fuel flow from the tank? Is the hs needle open 2-3 turns? Is the tank vent open? Is there a klunk in the tank that's stuck up?
#308
My Feedback: (16)
RE: Rc Fuel Faq
You cannot get fuel out of the tank unless air can get into the tank to replace the fuel that is being removed.
There needs to be a way for air to get into the tank
The clunk is the fuel pick up. It is flexible and has a weight on the end so it can go to the part of the tank where the fuel is.
Sometimes, this clunk gets stuck in the top of the tank
#309
RE: Rc Fuel Faq
I like your paper you have written, I believe you have done some good work as well taken the high road when needed. Lubricants are a tough thing to talk about as many people have many ideas of what is good or bad. Mol sieve will remove water from glow fuel it will also try to take a little methanol as it breaks the bond with the water and nitromethane as well as the water and the methanol>this will result in a temperature increase and can be very dangerous. I would say just do something responsible with the fuel and be done with it. I like your paper.
Wade L. Gray
Texas Allied Chemicals
Wade L. Gray
#311
RE: Changes?
ORIGINAL: mab0852
Can engines be converted to use real diesel? Would it be a waste because of the potential in the fuel or is there some other reason? I've seen gas conversions and Davis heads (faux diesel), but what about the pump kind?
http://www.freepatentsonline.com/20110146608.pdf
sounds more interesting. Kerosene is very much like (truck) diesel fuel, so if they got it to work with kerosene, it might work with truck diesel or with jet fuel.
Iskandar
#312
RE: Rc Fuel Faq
ORIGINAL: w4kv
Separating contaminating water from glow fuel
Water and methanol are completely miscible, meaning that one dissolves the other in any proportion. Freezing the mixture, letting it settle, etc., have no effectiveness at all. The oil and nitro may separate during such efforts, but the water and methanol stay together. There is no way to remove the water from contaminated fuel since distillation would destroy the nitromethane, and the presence of oil in the mix would make it a difficult, greasy process. With oil and nitro, the molecular sieve would be similarly ineffective.
You learn this in Geochemistry 101, by the way. Chemical/mechanical engineers will have come across this as well in their studies.
Iskandar
