Glow fuel, for all the chemists out there
RE: Glow fuel, for all the chemists out there
Albert, Martin,
The word 'methanol' (note correct spelling) has a couple (...) of synonyms...
...As you can see [link=http://www.chemindustry.com/chemicals/38239.html]here[/link].
It is an alcohol derived from the hydrocarbon 'methane', which is used as a gas for cooking in many countries.
In its chemical notation, methane is CH4 and methanol is CH3OH; a hydrogen atom (H) was replaced by a hydroxide (OH).
BC, CANADA
OK thanks for the info. That means I should be able to buy inexpensive gallon of methal hydate at the local harware, add 20% oil and end up with something close to FAI fuel.
Albert,
Just make sure it is at least 99% pure... doesn't contain harmful/acidic impurities.
And 'methal hydate' is not one of the names used to describe methanol.
Make sure the spelling is correct before you buy it, because if it is not methanol (or any of its synonyms), your engine will not run!
H'mm, the fuel bought at the race track seems to be a LOT cheaper than from the hardware store. About half. I suggest you find a good source of methanol race fuel.
Hi,I am using industrial type methanol,directly pouring from 200 liter barrel.Wihout nitro and 20% full castor with OS A3 plug,Im having good power. Fuel costs me about 3$ per litre
Costs about the same as a gallon of gas in the US. About $3.00 per gallon. That is for race fuel. A gallon of wood alcohol is about $6.00.
Hi, dont forget Im talking for Turkish market.Here a commercial brand fuel such as 5% nitro comes about 9,5 $ per litre.If I want to buy one liter nitro,I have to pay about 110$.My methanol costs me a little more than 1 $.
Banned
I think you guys had better check the CRC Handbook of Chemistry and Physics. Methanol is wood alcohol, methyl alcohol, or methanol. It is an alcohol.
There is no such chemical as methyl hydrate listed in the handbook and there is a listing for all the thousands of organic chemicals. The suffix hydrate indicates there is a water molecule in the base compound. You see this in many rocks and minerals. Opal is one. It's formula is SiO2-nH2O. It is SiliconDioxide with an n number of water molecules bonded to the SiO2. SiO2 is common quartz.
If you add water to methanol, all you get is contaminated alcohol.
Methanol and methyl hydrate (whatever that is) are two different things.
Definition of a hydrate from the glossary of "Chemistry and Chemical Reactivity, third edition". "An ionic compound in which water molecules are trapped within the crystal lattice." Methanol is not an ionic compound and does not have a crystal lattice. It is not a hydrate.
That was your chemistry lesson for the day.
BC, CANADA
True, the CRC does not list "Methyl Hydrate"... neither does the copy of the Merck Index I have. However... both are American publications and may overlook common or more antiquated names from the other side of the Atlantic.
I will refer you to the following link
http://ptcl.chem.ox.ac.uk/MSDS/ME/methyl_alcohol.html
and have attached the following scan of a bottle I have...
Banned
Again, the definition of a hydrate is an ion with water as part of the crystal lattice. Alcohol doesn't have a crystal lattice and it isn't an ion. In a hydrate the water molecule latches onto the atom that is missing an electron in the lattice. Alcohol don't do dat. I can write Rolls Royce on a Yugo but that don't make it a Rolls.
BC, CANADA
I suspect methyl hydrate is one of the more antiquated names for methanol and/or not commonly used on this side of the world.
However, that does not detract from the fact that methanol and methyl hydrate are synonyms. ( I apologize to all of you IUPAC lovers out there. )
http://www.hc-sc.gc.ca/ahc-asc/media...2001_07_e.html
http://www.centrum-labs.com/mobile/S...S/methanol.htm
http://www.mfa.org/_CAMEO/FRONTEND/m...hol&language=1
http://www.recochem.com/english/products/faqs.html
Also, while your description of hydration is correct, there is (at least) one other definition.
http://www.iupac.org/goldbook/H02876.pdf
AR
Methyl Hydrate
Is there a difference between Methyl Hydrate, Methanol, and Wood Alcohol?
Answer: There is no difference between these products; it is just a different name for the same thing.
Is there a difference between Denatured Alcohol and Methanol, or are they the same?
Answer: They are not the same, but in most workshop applications either one can be used. Otherwise, Denatured Alcohol is an ethanol-based product and is considered less toxic than Methanol. Check to see if the manufacturer specifies one in particular and follow the recommendation.
Where can I use Methyl Hydrate?
Answer: Methyl Hydrate, also known as Methanol and Wood Alcohol, is used as a fondue fuel, shellac thinner, gas line antifreeze, and, when mixed with water, as a powerful window cleaner.
End of story
End of story
BC, CANADA
And here I was trying to forget all that organic chem I learned. I'm going to have nightmares tonight, I just know it.
FWIW, denatured alcohol can be prepared by the addition of relativley small amounts of compounds such as benzene, methanol/methyl hydrate or any of about 90 or so others. You can probably find it in the UK as "methylated spirits"
As stated, the addition of these other compounds makes the ethanol poisonous. It also makes it taste awful, and darned near impossible to distill to anything worth spiking the punch with.
A really good chem lab might be able to clean it up, but would probably spend more money on reagents and grad student wages than they would have spent if they'd just gone out and bought a decent bottle of whisk(e)y. By denaturing the ethanol, it can be sold without all the taxes usually applied to the "good stuff" and be used in manufacturing etc.
BC, CANADA
I don't doubt that it did. My previous post wasn't terribly clear. let me try again. The addition of methanol/methyl hydrate to ethanol is only one way to denature it.
There are in fact a number (Approx. 50, according to one reference I have) of cocktails using some of over 90 different denaturants which are allowed to be called denatured alcohol.
Different recipes will be used for different things or different manufacturing processes...
I have been using 80% methal hydrate 20% castor for a while in my fuel.It doesnt have as much power or rpms as with nitro fuel
but it has been working not bad for my planes.I cant get glow fuel in merritt so I make my own.
GA
ORIGINAL: skateflyer
Does anyone know the difference between Methonal and Metholhydrate, (spelling???)is there any?????
PS: Methyl Hydrate is a synonym for methyl alcohol, which is the same thing as methanol, CH3OH. This is the same alcohol that folks distilled from various hair products and proceeded to go blind. So don't drink it, but your engine sure loves it. I knew it would pay off to take organic, inorganic, advanced organic and inorganic, physical chemistry, instrumental analysis, etc. It was to prepare me to make great model airplane, boat, and car fuels when I got older, but did not grow up.
Just to be topical, take a look at this lin on methane hydrates.
http://www.realclimate.org/index.php...lobal-warming/
Not trying to hijack the thread but what is the difference between ethanol and methanol for fuel use? I know you can drink the ethanol but in terms of btu's how do they compare? Will ethanol work as glow fuel?
GA
ORIGINAL: Grits
PS: Bulk production of methanol has been greatly improved over the years and can be made for as little as $.40-$.60 a gallon and a few years ago, you could buy 6,000-8,000 gallons for about 65 cents a gallon. Not true now, but we can make enough methanol for cars and model engines. Ultimately, we now reduce carbon monoxide with hydrogen under pressure and about 250 degrees. That is, methanol can be quite competitive with fossil fuels. Looked up heat contents for methanol and ethanol, methanol is about 62800 btu per gallon and ethanol is about 84400 btu/gallon or about 1.34 x as much for ethanol, compared to methanol. However, ethanol does have properties that make it better for relatively high rpm use in model engines. With the addition of nitromethane for oxygen, better idle and more power and more complete oxidation (in this case combustion) of methanol, the slight btu "handicap" for methanol is, in practice, not a problem. The reason you do not drink methanol, ever, is that your liver alcohol dehydrogenase enzyme breaks down methanol to formic acid and formaldehyde and that attacks your optic nerve, and can produce blindness.
