Man Down...
Man Down...
I just got my MCD back up and running(real fast!) and i experienced another lost wheel for the second time.
It seems that the nut came loose agian but upon inspection, I see what is probably the issue...worn wheel syndrome.
Is there a fix to rectify rounded drive cups on a wheel? TIA!
BTW, thanks to my buddy for towing me out of the field...
RE: Man Down...
i put wood screw through the inside of the rounded wheel drive cup. i used 3 screws, which bite onto the wheel hex on my baja. doesnt look pretty, but it will get me by untill i can afford a new set of tires/wheels.
My Feedback: (13)
OR
RE: Man Down...
is it 4 whel drive? if not, take some hot glue or something to build up the hex and put the worn wheel in the front, the fresh one out back... that's what I did on my Monster Buggy...
RE: Man Down...
you may be right there. my baja has the 23cc motor. im sure your MCD is heavier and more powerful. the trick is that the wheel nut HAS to stay tight. if it backs off then the screws COULD strip the wheel hex. on my baja, it hasnt been a problem. but with more power and weight it could be an issue.
what you need is a way to make a insert with a hex shape. wish i could help, but i did the screw fix cause i couldnt think of any other way to repair the wheel.
RE: Man Down...
ORIGINAL: bbuzzard
BTW, I found the trick over at the HBF...I knew it involved JB Weld...I have an idea to modify the steps a little but it will alleviate trying to find another set of wheels for cheap.
What i was going to say was; put some epoxy -or maybe even better JB Weld- in the hex, then put cellophane (to conserve food in/with) in the JB Weld , and then mount the wheel to the hex so it get the right shape. By using the cellophane you avoid the hex and JB Weld to adhere to eachother.
RE: Man Down...
ORIGINAL: Lars from Norway
I was going to write abot this last night but suddenly my keyboard didn't work
ORIGINAL: bbuzzard
RE: Man Down...
now why didnt i think of using quick steel? i have used it many times on cars. i would think it would work better than JB weld, as it is a putty...so it would be easy to shape and would hold its shape as it dries. the stuff stinks while you are working with it tho[&:]
RE: Man Down...
ORIGINAL: bbuzzard
What are they?
ORIGINAL: bentley marshall
you could try a set of these
