baja break queston
My Feedback: (17)
TX
RE: baja break queston
The baja break system consist's of a link system, It is attached to the throttle and actuated when you push forward on throttle trigger. A rod slides into a cam type setup that has a arm protruding. Move the protruding arm and it moves a cam which inturn mashes together break pad's (or binder's whichever you call them) around a break rotor. If you need some pic's I could shoot the brake setup on my baja. But it is a fairly simple setup and I still use the stock servo on mine and have no issues, But if you plan to run a hot motor then having the extra braking power is a good thing I run a Zenoah G26 and the brakes work fine with stock servo.
the baja is not for me im 15 and i fix nitro cars and a lady gave me $1500 to make her son a bad ass baja buggy so i going to buy the ss the boy has a spektrum ds3r so a reviver but i need to know what servos yall are running and any suggestons for any thing else
will the stock servo lock the tires
so far im putting the venom 5000 hump pack
set of paddles and runners
