rampage gearing
rampage gearing
have just gone through my first set of gears so have just installed the spare set that you get in the box, i have vented and put a filters over all the holes i have drilled so was just wondering if greasing these gears would prolong their life. I am just waiting for the hardened steel set to come into stock and wondering about greasing these as well
RE: rampage gearing
Make sure your brakes aren't dragging and that the truck rolls freely when the throttle servo is at neutral position up to full throttle. Those gears should probably hold up ok unless undue heat is being introduced due to resistance in the drivetrain or you are running in heavy mud or grass or something....
