Samba / F1 FG question
Hello all,
I'm looking to replace the stock pipe on my FG Comp F1 and was thinking about a Samba. I'm confused about how the options stack up though. As I understand it, they are;
Samba F1 (with the 'up and over' carbon can) looks to be pretty quite because of the overall length
Samba F1 G pipe. Does this come with a ceramic coating as standard? It looks to have less length and bulk which I guess gives it lightness and less back-pressure at the expense of noise?
Samba F1 G RMC pipe. Not sure what the RMC moniker means...
I've deliberately left out the Ti option because although it's super-sexy it's out of my price range
Thanks for any help and advice!
Darren
Darren
RE: Samba / F1 FG question
ORIGINAL: culky
Hello all,
Darren
Hello all,
Darren
Are you sure it's RMC not DMC - DMC is the German governing body and pipes that carry that mark are legal in the German championship.
Hi Mike, thanks for the response. It was definitely RMC and not DMC, although your explanation of DMC would make perfect sense.
I've done a little bit more digging on the ModelCargo website and I've found RMC refers to 'removable cap' which makes for easier cleaning. I found the explanation in the online shop, relating to a different pipe. That's one mystery solved
With some time to do a bit more research (I found the ModelCargo forum), I think I've managed to answer my own question:
F1 'G' pipe:
F1 'G RMC' pipe:
I think most are homologated by the DMC.
I think I'll go for a basic F1 pipe and save some pennies to spend on bodyshells.
PS if anyone has any build info/photos for the FG Comp F1 Hydro I'd appreciate it. I've not built one before.
F1 'G' pipe:
The new batch of our very successful Formula 1 pipe is now available with the new ceramic coating. High temperature resistance keeps the heat in the pipe to increase engine performance. There is also a new way of mounting on the car. We use a clamp to fix the pipe as flexible as possible with no risk of getting loose on the car.
Small changes make improvement on low power.
This pipe has also a removable cap system for easy cleaning.
