RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
BodySax/MTC water cooled twin
Reply
Old 01-12-2011, 10:00 AM
Saxtoft
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default BodySax/MTC water cooled twin
I could see there is some price confusion. This has been cleared now. Seem that it was somethings with the VAT.
On the joined crank versus the one piece crank there are some pros and cons.
Joined cranks have the advantage of regular bearings and better sealing between the two cases (room under the pistons). The disadvantage is of cause the joint. One piece (if made well) does of cause not have an issue of the joint. Problem here is that you have to use a two piece bearings and the sealing is difficult. On our case we use larger than standard bearings as well as we use 5. On the RCMK roller berings are used betweem the two cylinders and a double groove seal (air spinning) is sealing the two cases. One of our "watch and learn points" of the split roller bearing is related to the way the forces are transmitted from the explosion to the crank and the case. If this proves to be capable of withstanding the forces then the one piece crank is a good solution. On the other hand, the joining method we are using has already been proven to last and hence MTC gives 5 years warranty on the joint.
Questions, just ask.
Saxtoft is offline
Old 01-12-2011, 10:38 PM
splcrazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: BodySax/MTC water cooled twin
so do you have any pictures of this installed into a 5b ? and a video of it running ? or any other pictures we havnt seen, im curious to see what those radiators look like
splcrazy is offline
Old 01-13-2011, 07:44 AM
Saxtoft
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is an older picture. Today the sit a little closer together.
You can ckeck out my photobucket for more pictures.
It has not been installed in a 5B before. Installing in a B will require some modifications to the roll cage as the spark plugs sit right where the bars run.
Saxtoft is offline
Old 01-13-2011, 08:08 AM
mooman007uk
mooman007uk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how long is the motor?
those rads are slick...are these and the pump available separately?
mooman007uk is offline
Old 01-13-2011, 02:02 PM
Saxtoft
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The case itself is 122 mm. Then comes the clutch house in one end and the ignition plate and pull starter in the other end.
Saxtoft is offline
Old 01-13-2011, 02:05 PM
Saxtoft
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some more pictures
Saxtoft is offline
Old 01-13-2011, 04:15 PM
splcrazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats the meanest beast ive ever seen , do you have a vid of it going ? .
splcrazy is offline
Old 01-13-2011, 08:38 PM
Saxtoft
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Search on 5Twin or msaxtoft on youtube. There are a few
Saxtoft is offline
Old 01-15-2011, 10:18 AM
nitrohead5300
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saxoft looked at your video of your car running on grass I think you really need a 4 wheel drive system when you are running your twin beast on a surface other than sand. That twin inline motor is a beast!!!
nitrohead5300 is offline
Old 01-15-2011, 01:54 PM
Saxtoft
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sand rail version is being build as we speak....
Saxtoft is offline
Old 04-07-2012, 05:58 AM
splcrazy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can i run air cooled cylinderheads on this ?
splcrazy is offline
Reply
Display Modes
