break down
RE: break down
perfect thanks. i have a king motor 5t and had to get a new steering servo. ended up buying a hitech but the mounts were differnt so i had to but the whole new electrical box. and another neath the servo out in fron where the steering part connects to it was a wierd bracket attached to the frame. im trying to figure out what its for
AZ
RE: break down
I don't see it specifically called out in the 5T manual, but if you look on page 11, step 7 in the box showing how to adjust the steering linkage, is it the bracket you can see under the servo arm, just to the right?
I believe that was designed to have a bolt inserted in the non-slotted hole and adjusted so that the servo arm hits it before it can over extend. In the SS manual, it says to install the bracket, but not a bolt or how to adjust it.
