5b front shock tower support
RE: 5b front shock tower support
ORIGINAL: LOST IN MN
Page 2 image 3 of the ss manual. Its the front bulkhead support
Is that an Integy part the one you have pictured? If you want a full alloy car then you are going to need both the bulkead and that piece.
Here is a pic you can kind of see it
Also if you want to save yourself a huge headache later....If using any Integy parts that come with screws don't use them. They are made from extremely soft steel or aluminumand will strip out or break with the slightest amount of force. Get yourself a TONY's 12.9 grade screw kit.. You will thank me for that later when you need to take the car apart!!!!!
Also if you want to save yourself a huge headache later....If using any Integy parts that come with screws don't use them. They are made from extremely soft steel or aluminum and will strip out or break with the slightest amount of force. Get yourself a TONY's 12.9 grade screw kit.. You will thank me for that later when you need to take the car apart!!!!!
