cy chrome engine covers
When is someone going to make this part in billet form ? im sick of these covers peeling and looking like crap after a few months .
RE: cy chrome engine covers
true dude, but at the same time, would cost a bomb prob & also be pretty heavy :s
probably better off getting a head kit wit an anodized head & not use the cover at all
yeah but all say not using the cover causes overheating and engine failure which happened to me once when i used that anodized head without the cover .
ORIGINAL: Lars from Norway
I just can't get myself to think that this setup provides enough cooling to the head.
if anything having the cover on would cause over heating probs, but with no cover = more air getting to the head which is why it works i guess \o/
Actually the cover on allows for more cooling as it directs the air from the flywheel over the head. Head kits like the ADA use more surface area to achieve cooling.
ORIGINAL: tizdaz
FL
ORIGINAL: splcrazy
your wrong the cover must stay on because the air from the fly wheel goes up and is caught from the cover to circulate around the head . without the cover you will cook your piston ring
ORIGINAL: tizdaz
ORIGINAL: alvinm
The post ahead of yours said the same thing...
ORIGINAL: splcrazy
ORIGINAL: tizdaz
