Gearing or pipe for new 30.5?
FL
I want to get more top end speed out of my Baja, which has a stock 30.5 with a RD Logics pipe. I was wondering if there would be a more noticeable gain using taller gears or would I be better off with a big bore type pipe? Any recommendations on pipe or spur/pinion combo that would help?
MI
RE: Gearing or pipe for new 30.5?
is your motor winding out? you could try gears first- hostile has sets for $30, and thats prolly your cheapest route for speed. if that doesnt help your speed any, than look into a pipe. victory pipes are pricey but worth it-
FL
I haven't. I pull on them from a dead stop but they seem to eventually catch me. Would going down a tooth on the pinion help?
NY
There engines are smaller cc if they are the stock ones. Which rev higher then yours. The larger bore 30.5 will have more low end grunt, but cant get the rev's the 23, 26, etc cc can get. Of course you have the extra torque to pull taller gears. So thats what I would do.
Dear Professional of BAJA 5B
i have change Motor to CY 30.5 cc complete with JET PRO thunder pipe to my BAJA 5B, not easy to control
the existing gear 17/57. if i need to change the new ratio. how about it should be....?
thanks in advance for your kindly assist..
Noom-RC-Thailand
Holy free translation, Batman!!
To change gears, you need to access the existing gear and swap them out. Make sure the combination of both gears adds up to a total of 74 teeth and you should be good to go. Keep in mind the larger the smaller teethed gear, the taller the gear ratio.
ORIGINAL: bbuzzard
