New 2 speed design for Baja
Inovative Hobby has a new 2 speed design made by Integy for the Baja. This new 2 speed is based on the clutch design instead of the pawl. The BSW 2 speed is based on the pawl design. I wonder which one of these 2 designs will put less stress on the drivetrain ?? And which one of these designs will give you the best performance?? Which one of these designs do you think is the best??
RE: New 2 speed design for Baja
ORIGINAL: badboy2
it looks like the brcp 2speed for baja ...the design is also similar to fg trucks/cars 2 speed.innovative hobby got some nice products..
ORIGINAL: badboy2
oh ok...you theres also TGI 2 speed made by turboglenn ..he uses hostile spurs .more choices much better for us!
I use to race 1/8 scale onroad cars. My first onroad was a BMT 891 Blitz, it had a pawl design 2 speed it was wicked fast but the 2 speed pawl design played havoc on the drivetrain!! I was always repacing drivecups and dogbones. This problem was common for any 1/8 scale onroad car that used a pawl design 2 speed. Then I saw a video by RON PARIS advertising a new design 2 speed tranny that used large clutchshoes I had my doubts , I figured tthis design 2 speed would slip too much........WRONG!! The clutchshoes design 2 speed proved to be superior to the pawl design causing less wear and tear on the drivetrain and faster acceleration because of less rotrational mass on the drivetrain . My Losi LST had a clutchshoes design 2 speed on it and it was awesome!! I believe that the clutchshoe design 2 speed will prove itself superior to the pawl designs eventually.
My Feedback: (13)
ORIGINAL: nitrohead5300
.................Do you know if his design is a pawl design 2 speed ??
ORIGINAL: badboy2
im not really sure ,but you can find him in baja forums..i think it looks similar to these designs..
MI
the pawl type are a grenade when they shift. the clutch shoe type have a larger surface area for engagement, so there is less wear on a single point.
Frankly I had never seen the pawl type back then. I really never heard of those until recently. But anyway, the clutch type does work better. It's probably less of a shock load to the drivetrain because the clutch will slip a little before it fully grabs.
