1/5 oil leaking
1/5 oil leaking
I Have a redcat rampage mt that leaks oil from the heads of bolts that holds the muffler. I have replaced the gasket and I am using a ratio of 25:1. and running out of solutions can anyone help
GA
RE: 1/5 oil leaking
Here is what I am talking about. It is made by Permatex.
http://www.permatex.com/products/aut...sket_Maker.htm
GA
RE: 1/5 oil leaking
Here in the states any auto parts store carries it. I never had a problem with leaking exhaust gaskets might be do to using the Ultra Copper. I do recommend after sealing and installing the gasket to let it set at least over night before running it. I normally let it set 24 hours.
IN
RE: 1/5 oil leaking
This sealant works great for sealing are head gaskets here;s a link to were you can get it
http://www.largescalerc.com/motoseal...llengines.aspx
