Obr engine
RE: Obr engine
its a 2 piece top n bottom.you place the shaft on the bottom block wif bearing n enclosed the top block there u got the centre done den u fix the left n right block in u get a set of crnkcase wif shaft splcrazy..den u put on the cylinder on top of the block u get a set of powerful engine..dast wat hes trying to say..its abt obr engine n not other topic..dun be misleading..
RE: Obr engine
i cant remeber but its from a boat website for rc... the have v1 and v2 guess version 1 or 2
the price was surprising..and was the same pic posted in this forum..
GA
RE: Obr engine
Yes you could buy a stock RCMK V2 S-520 engine. Then all you would have to do is buy two air cold cylinders and if you want them ported more cost or do it your self. Then you need engine cradel mount (mounts engine to rear chassis plate, rear bulkhead, main chassis), tranny plate, 2x air boxes, clutch housing and chassis mount make a longer lay shaft, head heat sink, throttle linkage and exhaust system. If someone does it let us know what it cost.
