Rampage MT Pro
Rampage MT Pro
i can use personal experiences from owners of the Rampage MT Pro ! is it worth the money, durability, etc.. will a painted body from an XT or MT fit the Pro version ? any of your thoughts to share with me because I,m considering buying one!
Also does the Tuned Pipe melt the body?
Lenny7118
Lenny7118
IN
RE: Rampage MT Pro
A friend has one and it run good the servos are not that good i would upgread the radio and servos. the pipe hasnt melted yet and the MT XT bodys are the same size
RE: Rampage MT Pro
Yes the bodies are the sameand will fit both the hole post mount are different the tuned pipe will metl the body if you run wide open in long wide open runs, but a easy fix for that is place aluminuim tape on the inside back of the body to keep the heat off of the body and it will not melt . The MT is a beast most dependable 5th scale that I own is very dependable and well worth the money you will have a blast with it get one!!!!!!!!!!!!!!!!!!!!!!!
GA
RE: Rampage MT Pro
ORIGINAL: rchobbyunlimited
Yes it is very much so.
ORIGINAL: 46u
From what I have read the MT is much more durable then the XT.
