best sounding silenced baja 5sc exhaust under $185
CA
Looking sor a great sounding silenced baja exhaust that sounds like it makes popping sounds (backfires a bit when gas is let off) any pipes that will do that?
AZ
RE: best sounding silenced baja 5sc exhaust under $185
No pipe is designed to do that. Your best bet is to talk to an engine builder and have them set the timing so it does that when you want.
AZ
I use the Flowsystem Racing pipe.
The best pipe depends on your own taste and situation. There are plenty of options out there.
