25% Oil Mix...Misprint?
I went to start my Redcat 30cc gas engine for the first time with a 4% oil mix in the tank and was shocked to see a sticker on the engine asking for 25% oil. Do they really want it that oily during break-in?
NC
RE: 25% Oil Mix...Misprint?
Actually, 4oz of oil per gallon is 32:1. For 25:1, you need to put 5.12oz of oil per gallon. I know that this is splitting hairs, but it might might help you engine to run cooler and last longer.
Scott
PS there are 128oz in a gallon
Scott
CA
Its not an oily mix if you tune your engine right. My stock 26cc is almost 2 years old using Tanaka at 25-1 ratio. Use less oil and youll be buying a new motor.
do you guys have any issues withe the engine carboning up ( if thats a word) at 25:1. when i run my mixture at 25:1 my 26cc carbons up so bad it wont run any more but has been better since i changed my mixture to 45:1 using av gas and synthetic 2 stroke oil. it got so bad i had to take the motor apart and scrape the carbon off the piston and cylinder head.
FL
ORIGINAL: jdw652
FL
ORIGINAL: jdw652
i noticed a good increase in power and seems to run a little cooler too. i also like the smell.
i should have mentioned i guess that my ratio is metric , milliliters to liters works out to be 22.5 ml oil to 1 liter gas i'm not sure what that is in ounces and gallons
Mine stated 35:1 (winter) / 32:1 and im kind of wondering if thats on the rich side. Albeit i cant recall if the 2cyl oil is a synth or not
CA
Isnt AV gas like 100 octane? Higher octane fuel burns slower than lower octane fuel, I dont see how you can get a power increase from that, other than the lower oil content you are using... High octane is for higher compression ratios, so the fuel doesnt pre-ignite.
im not sure what to tell you then but it sure seems to make a diferance and the stroker kit i put in it says to run premium high octane fuel or race fuel
CA
Oh, well the stroker or big bore are higher performance kits, and so they probaby would require the higher octane. My sttock 26cc wouldnt see a benefit. I use the 25-1 ratio with a quality oil Tanaka for example, and dont see any oil spewing out like a nitro, or carbonizing too much. I want the extra oil cushion on my needle bearing...
