RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Nutech 5SC Build
Old 04-08-2012, 08:18 PM
NUNCHUCKSKILZ
Default RE: Nutech 5SC Build
You need to do this build on Nutechracingforum too.
Old 04-08-2012, 08:19 PM
pwaicon
ORIGINAL: BOOSTED-ELKY
Looks Great! Keep up the great work!
Thanks!! I don't know what takes longer the actual build or going through all the pics.
Old 04-09-2012, 05:15 AM
noyb98098
As usual, looking good pwaicon.. Can't wait for some track vid.. Will this be making an appearance at power jam perhaps??
Old 04-09-2012, 07:53 AM
elven wizard
elven wizard's Avatar
Pwaicon you always meticulously put in great attention to detail in these builds. [8D] very nice ! I have been out. Can't wait to see the video.
Old 04-12-2012, 04:11 AM
rckiwi
rckiwi's Avatar
Great to see you have another Nutech build Brian, I have the TBIII buggy and loving it! All the upgrades required from the TBII have been done and handles and drives so much better. I have been using mine straight from the box which I received from the factory as a roller. I fitted a 4 bolt CY27cc motor, Hitec servos and custom made side pipe. I have done 2 rounds of our race series and the plastic gears have held up fine but I did remove the cover to allow for better cooling of the gears. At the moment I am 2nd behind a race trimmed out MCD V4 and most of the others in my class are all MCD's.
3rd round is this weekend so will be changing a few things like diff and shock oils to suit our track hopefully get on top of the MCD's!
Cheers Bryan Taylor
Ex RC Innovations Ltd New Zealand.
Now PowerSlide Racing Australia.
Old 04-12-2012, 04:12 AM
  #31
rckiwi
rckiwi's Avatar
double post???
Old 04-12-2012, 07:55 AM
  #32
nutechracingusa
nutechracingusa 's Avatar
Nice tear down pwaicon, as for the new hub bearings I've been running my TB III and TB II brushless electric with the nylon spacers since the end of last season and still haven't seen and wear to the nylon or the hubs. I was able to find those 12x22x7 bearings just in case there was a issue but I haven't needed to install them yet.
http://www.bearingsdirect.com/store/..._detail&p=4308
Old 04-12-2012, 07:00 PM
  #33
pwaicon
ORIGINAL: elven wizard
Thanks EW, hopefully you will get to drive it sooner rather than later. Are we still on for RCX?
Nutechracingusa,
Thanks for the link to the bearings. Glad to hear you haven't had in issue with the stock bearings and spacers.
rckiwi,
Sounds like you are having good success with the TBIII and giving the MCD's a run for their money. I am also not planning on running the gear cover so it is good to hear the stock plastic gears are holding up for you. Good luck this weekend!!
Noyb,
Thanks. Since Milestone closed I haven't had much track time with any of my cars, so it looks like the SC5 is going to see more bashing than track time. As for attending Power Jam....I would love to make the trip, but it is not looking good at the moment.[]
NUNCHUCKSKILZ,
Good ideal.
Old 04-12-2012, 07:13 PM
  #34
pwaicon
More pics of the dual steering set up.
ID:	1749585   Click image for larger version
ID:	1749586   Click image for larger version
ID:	1749587   Click image for larger version
ID:	1749588   Click image for larger version
ID:	1749589   Click image for larger version
ID:	1749590   Click image for larger version
ID:	1749591   Click image for larger version
ID:	1749593   Click image for larger version
ID:	1749594   Click image for larger version
ID:	1749595   Click image for larger version
Old 04-12-2012, 07:20 PM
  #35
pwaicon
Finishing up the steering and installing the side guards. I decided to notch out the side guard on the gear side. The gear cleared the guard so it wasn't necessary, I just wanted a little more space around the gear.
ID:	1749600   Click image for larger version
ID:	1749601   Click image for larger version
ID:	1749602   Click image for larger version
ID:	1749603   Click image for larger version
ID:	1749604   Click image for larger version
ID:	1749605   Click image for larger version
ID:	1749606   Click image for larger version
ID:	1749608   Click image for larger version
ID:	1749609   Click image for larger version
ID:	1749610   Click image for larger version
Old 04-13-2012, 10:58 AM
  #36
elven wizard
Pwaicon, Like to go to RCX. Will see. Got in trouble again. I'll have to give you a call.
Old 04-15-2012, 05:32 AM
  #37
hndaman1
hndaman1's Avatar
my question is you did all that work and yet you still used plastic diffs? the plastics ones are poo. should've went with the alloy..especially on the center....
Old 04-19-2012, 04:55 AM
  #38
pwaicon
ORIGINAL: hndaman1
I really don't have any experience with the Nutech plastic diffs, my other Nutech is a TBII Pro which is all alloy. I have read others thoughts and experience with the plastic diffs but I figured it was time to try them out for myself. If they are indeed "poo" then I guess I will have to have some alloy ones standing by.
Old 04-19-2012, 06:43 PM
  #39
rckiwi
rckiwi's Avatar
ORIGINAL: hndaman1
There is nothing wrong with the current versions of Nutech's plastic diff cases or outer housings!
Old 04-19-2012, 06:45 PM
  #40
rckiwi
rckiwi's Avatar
ORIGINAL: pwaicon
rckiwi,
Thanx man yes car is going great unfortunately in the last round final a rear dogbone broke due to the rough conditions the track ended up in
I can't see any advantage in trimming the side guard like you have?
Old 04-21-2012, 06:14 AM
  #41
pwaicon
[/quote]
[/quote]
I just figured if later down the line I started to play around with the gearing ratios there might be a clearance issue, so I figured I would just take care of it now so I wouldn't have to take them off later if it there was an issue. But you are probably right, there is no real advantage and probably wasn't really necessary.
Old 04-21-2012, 06:19 AM
  #42
pwaicon
Finishing up the front end and starting on the bumpers and again I added some longer bolts with locking nuts on the lower arm mounts.
ID:	1753022   Click image for larger version
ID:	1753023   Click image for larger version
ID:	1753024   Click image for larger version
ID:	1753025   Click image for larger version
ID:	1753026   Click image for larger version
ID:	1753027   Click image for larger version
ID:	1753028   Click image for larger version
ID:	1753030   Click image for larger version
ID:	1753031   Click image for larger version
ID:	1753032   Click image for larger version
Old 04-21-2012, 06:30 AM
  #43
pwaicon
Finishing up the front bumper and starting on the rear. The front bumper looks like it should hold up nicely...the rear I am not so sure of.
ID:	1753034   Click image for larger version
ID:	1753035   Click image for larger version
ID:	1753036   Click image for larger version
ID:	1753037   Click image for larger version
ID:	1753038   Click image for larger version
ID:	1753039   Click image for larger version
ID:	1753040   Click image for larger version
ID:	1753042   Click image for larger version
ID:	1753043   Click image for larger version
ID:	1753044   Click image for larger version
Old 04-21-2012, 06:40 AM
  #44
pwaicon
Installing the rear bumper and the shocks. I decided not to mess with the shock....they are not my favorite thing to work on, besides they didn't change anything on the shocks from what I can see. The wheels and tires look to be decent for a RTR. I haven't tired it yet but I am pretty sure that any tire that would fit on a HPI 5T or a Losi 5IVE should also fit on the Nutech SC5 wheels.
ID:	1753047   Click image for larger version
ID:	1753048   Click image for larger version
ID:	1753049   Click image for larger version
ID:	1753050   Click image for larger version
ID:	1753051   Click image for larger version
ID:	1753052   Click image for larger version
ID:	1753053   Click image for larger version
ID:	1753055   Click image for larger version
ID:	1753056   Click image for larger version
ID:	1753057   Click image for larger version
Old 04-21-2012, 09:56 AM
  #45
pwaicon
Installing the engine, I decided to go with Gizmomotor's 30.5 long bock engine, and a Nutech 3shoe clutch. I also added an FG radio box to the side of the sock one to give me some much needed extra space. The radio box on the Nutech is just too small for my liking, that is one thing they didn't change that I wish they had.
ID:	1753115   Click image for larger version
ID:	1753116   Click image for larger version
ID:	1753117   Click image for larger version
ID:	1753118   Click image for larger version
ID:	1753119   Click image for larger version
ID:	1753120   Click image for larger version
ID:	1753121   Click image for larger version
ID:	1753123   Click image for larger version
ID:	1753124   Click image for larger version
ID:	1753125   Click image for larger version
Old 04-21-2012, 10:04 AM
  #46
pwaicon
Installing the rollcage and pipe. I decided to use the Samba pipe from my Titan, it worked well on the Titan so I think it should work well on the SC5. The Samba isn't the loudest pipe but it has a nice smooth power band and it fits under the body. Speaking of the body, I cut the body where it was hitting the top of the rollcage, this allows the rear of the body to sit lower. Overall the truck went together nicely, there were no fitment issues with any of the parts. My main concern is the rear bumper and I would have really preferred a clear body so I could have painted it myself. A complete redesign of the body wouldn't be a bad ideal either.
ID:	1753132   Click image for larger version
ID:	1753133   Click image for larger version
ID:	1753134   Click image for larger version
ID:	1753135   Click image for larger version
ID:	1753136   Click image for larger version
ID:	1753137   Click image for larger version
ID:	1753138   Click image for larger version
Old 04-22-2012, 11:24 AM
  #47
Bulldogger
I have been trying to decide between this and the Mega beetle any thoughts? also can you use there factory radio gear or is it sub par like HPI's.
Old 04-23-2012, 02:15 PM
  #48
hndaman1
hndaman1's Avatar
ORIGINAL: nutechracingusa
Im thinking of using the HPI rear hub/bearing setup.. I already replaced the stock bearing with avid bearings.. and there is tons of play already...
Old 04-23-2012, 02:19 PM
  #49
hndaman1
hndaman1's Avatar
boca bearings has them also.. but they are going to cost ya.. don't forget we get a TRACK discount yet....
http://www.bocabearings.com/bearing-...2X22X7-12x22x7
Old 04-26-2012, 05:00 AM
  #50
pwaicon
ORIGINAL: Bulldogger
I have never used the factory radio gear so I really can't say if it is any good or not. However, from my experience with other stock radio gear it has never been all that good. As for the Mega Beetle and the SC5 it really comes down to preference. The beetle does have the wider stance and I have always liked the beetle body, I think it is my favorite body style.
