Insane 1/5 scales with Big Blocks in them!!
#202
RE: Insane 1/5 scales with Big Blocks in them!!
I think it will do 130mph. Anything above 100 will be Ok at the start then with some tweking increase the speed
I got the gearbox parts back from being hardened today so will test it on the road, if I can find some road not covered in snow!
Cheers
Cheers
#204
Just tried the car in the road and the grub screws holding the gears keep coming loose. I'll try to tighten them tomorrow as its getting dark now. Otherwise I will have to think about keying the gears on
#206
BC, CANADA
loving the trannie...for even more oomph off the line and top end you could always throw a wet NO2 kit on it and make up a fogger plate...be pretty easy to add 50% to your hp with enough happy gas i'm still real tempted to throw one on my foff twin build if it needs it..
#207
Changed the clutch springs and fitted an air filter and shes nearly ready to test. The back belt creeps along the pulley so I will put some sides on the pulley to stop it wandering around.
Uploaded with ImageShack.us
I'll change the radio gear also as it was a bit glitchy. testing is in May
Cheers
Cheers
#209
18kg or nearly 40lbs before the weight reduction. I can't see it gettting below 16Kg with the shell on.
The engine can push a 20Kg bike with a 70Kg rider on to 70mph with a single gear.
Cheers
Cheers
