RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
My Zenoah 26 wont start.
Old 05-16-2012, 02:22 PM
morespeed
Default RE: My Zenoah 26 wont start.
here's another thing to try, take your plug out turn your baja upside down and pull start about 10 times. this is flush it out if it is flooded.
next put about 8 drops of 2 stroke oil in the cylinder and replace the plug and give it a pull. it should try to pop or it may fire right up.
if it starts and then dies and will not start back up it may be the carb.
Old 05-16-2012, 02:27 PM
morespeed
maherbeemer, i thought the same thing. mine looked new but i changed it anyway just to see. just so happened i had another carb sitting next to me
so i took that part # out and switch them and . wow it started
Old 05-16-2012, 02:48 PM
maherbeemer
Thanks for the info, I will give it a try when I was cleaning the carb I never took the bottom part off so maybe it got glogged up or something but I will try it and let you know.
ORIGINAL: morespeed
Old 05-16-2012, 03:29 PM
tapkoote
I did mislable the float diaphram
if you get the carb rebuild kit, it will have a blue plastic like
pump diaphram which is stiffer than the stock, and will hold up
better
Old 05-18-2012, 01:56 AM
maherbeemer
Thanks for the info; I won't have time to work on the motor at the moment but I will try to open the bottom diaphram and see, as for the pump diaphram it wasn't wrinkled but it might be one of those two.
ORIGINAL: tapkoote
better
Old 05-22-2012, 12:52 AM
  #31
maherbeemer
I made an order for both the lower diaphram and upper one; so once they arrive I will give it a try and hopefully have the engine running again.
Old 05-22-2012, 01:49 AM
  #32
maherbeemer
Morespeed,
Do you mean gasoline mixed with 2 stroke oil or are you reffering to 2 stroke oil alone.
ORIGINAL: morespeed
Old 05-22-2012, 01:23 PM
  #33
Lars from Norway
Lars from Norway's Avatar
I guess he means only oil, this is to increase the compression in the cylinder. Again, i guess
Old 05-22-2012, 01:38 PM
  #34
tapkoote
this is quite a puzzle lets us know if you get it started
have you tried disconnecting the kill switch?
Old 05-22-2012, 03:26 PM
  #35
morespeed
sorry guys,
been gone racing at the east coast large scale nationals. the guys i was with took 1st in 3 classes.
lars is correct. oil only this will bring up compression.
Old 05-22-2012, 09:29 PM
  #36
maherbeemer
sorry guys I am at the oilfield so wont be able to work on it yet; but will keep you posted I think it just wasn't getting enough fuel.
Old 05-22-2012, 09:45 PM
  #37
maherbeemer
No I haven't; but as soon as I get my break off work I will be able to work on it, I will try chaging the diaphrams first.
ORIGINAL: tapkoote
Old 05-23-2012, 02:42 PM
  #38
Lars from Norway
ORIGINAL: maherbeemer
But it don't seems like it is getting too little oil, with you being at the oilfield Sorry, i just had to!
Old 05-23-2012, 03:07 PM
  #39
morespeed
Old 05-23-2012, 09:28 PM
  #40
maherbeemer
HHHHH
Old 05-23-2012, 10:18 PM
  #41
tapkoote
WHATT????
SHOULD HAVE BUCKETS OF OIL
Old 05-23-2012, 10:29 PM
  #42
badz
badz's Avatar
A engine needs only 3 things to start, compression,fuel and spark. So see which of those you don't have. Did the engine ingest dirt? If so you probably have no compression, hence it won't start, this is the most common reason for engines failing.
Old 05-23-2012, 10:44 PM
  #43
maherbeemer
I still won't be home yet; so can't work on the engine I will replace the diaphrams and see if thats the problem....and no it did not ingest dirt but incase there is no compression whats the best way to make sure that i have the correct amount, I made sure the engine is sealed.
ORIGINAL: badz
Old 05-23-2012, 11:18 PM
  #44
tapkoote
THE drill with the oil in spark plug hole will tell you about compression.
good luck
tap
