nylon stock for custom fabrication?
RE: nylon stock for custom fabrication?
google an engineering plastics manufacturer/supplier local to you.
Do you want compression/shear/flex/tension/torsion properties in your component manufacture?
There's many different plastics for many different jobs/applications.
A servo saver (plastic cam type) may be a different plastic to an A arm, as would also chain tensioner, wing mount, suspension bush.
You should find nylon material (strip, sheet, rod & bar) at most bearing/industrial supply stores too. Tell them which part you want to make, and I'm sure you should be pointed to which type to use for each part.
Well ebay does sell awesome batteries!!! Not mine tho just accused of soliciting someone elses stuff!!!!<pre style="line-height: 17px; white-space: normal; color: rgb(42, 42, 42); font-size: 13px; ">
http://www.ebay.com/itm/271087058436...84.m1555.l2649
http://www.ebay.com/itm/271087060641...84.m1555.l2649
http://www.ebay.com/itm/271087063695?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2 649</pre><pre style="line-height: 17px; white-space: normal; color: rgb(42, 42, 42); font-size: 13px; ">
http://www.ebay.com/itm/271087067925...84.m1555.l2649
http://www.ebay.com/itm/271087071975...84.m1555.l2649
http://www.ebay.com/itm/271087054041...84.m1555.l2649</pre>
AZ
