RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Homebuilt Weedeater RC - Clutch
Reply
Old 02-21-2013, 10:46 AM
polaco1782
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Homebuilt Weedeater RC - Clutch
Hello guys.
I'm new to this forum, and I would like to hear some ideas from you all.
I've build a giant scale car, but I'm having some problems with the motor clutch actuating too early.
This is how it's being built.
This is a standard weedeater clutch. The gear is 1:6 ratio.
Replacing the clutch spring would help to delay a little bit more to actuate?
polaco1782 is offline
Old 02-21-2013, 12:39 PM
Twin_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Homebuilt Weedeater RC - Clutch
What a Frankenstein!!
IMO, without replacing the entire clutch to some aftermarket item, going to a heavier spring is the only way to change when the clutch engages. The softer the spring the earlier the clutch engages.
Its if its possible to lighten the clutch shoes it should also change when it engages. The less weight the shoe has the more RPM it needs to move.
Love to see a video of this thing in action!
Good luck!
Bill S.
Twin_Flyer is offline
Old 02-21-2013, 01:00 PM
polaco1782
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL, thanks for the reply!
Yeah, it is a real frankenstein. I'm currently finishing it, but as soon as I can I'll post a video.
I'll give a try on that. the clutch shoe still new. I can lighten it a lot. Thanks for the tip.
Old 02-21-2013, 09:22 PM
Dirty_Vinylpusher
Dirty_Vinylpusher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is awesome!
Love seeing these kind of projects.
This is what home building is all about.
Reminds me a lot of my earlier projects.
As you're running such big wheels you could probably reduce the gearing a bit further to 8:1 or even more.
I've tried putting RC clutch springs on these sort of motors and a 6000RPM spring was way too stiff.
It only JUST engaged and the car crawled along at full revs.
If you lighten the shoes make sure you take the exact same amount off.
Drilling holes of the same size would be the best way.
Also I would like to see more photos of how you've mounted the engine.
Once it drives there's a lot of stress on the mounts and you don't want it to come loose....
Dirty_Vinylpusher is offline
Old 02-22-2013, 04:33 AM
polaco1782
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey DV, thanks for replying!
This is my first ever attempt to build a RC. I've seen a lot of your projects, taken some ideas from them! Thanks for sharing!
Yes, I think I'll have to increase the gearing as you said, but first I'll try with the clutch ideas. Lets see what happens
Errm, about the steering... How many kilos a servo motor is needed? I have not tested yet, would a 17kg servo work?
I'll take more pictures this weekend, as I'm doing it on my father's house.
Old 02-22-2013, 02:54 PM
Lars from Norway
Lars from Norway's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It might work, but if you get a Hitec HS-805 MG i think this will be sufficient. This is 24,7 kg on 6 volt. Reasonably priced too
I like your build! I wish i could make mine this "uncomplicated" too, hehe! Will be nice to see more of it.
Lars from Norway is offline
Old 02-25-2013, 11:28 AM
polaco1782
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey thanks!
I'm thinking in dual servos. My radio supports channel mixing, so I can setup it to control 2 servos at the same time.
I'm using a turnigy-1501 servo, it is 17 kilos on 6 volts.
At home I'll post some new pictures.
Old 02-25-2013, 02:52 PM
Lars from Norway
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why use channel mixing, when all you have to do is to run an Y-cable and control the servos on one channel?
Old 02-26-2013, 09:30 AM
polaco1782
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My radio has 6 channels, and I dont know if a split would work fine. I've read some posts people claiming that it will overheat the servo. I'm not sure about it
I've recorded a video, first time run!
Ah, the clutch is fine, I will not need to change the spring. I found out that the carb was dirty and the engine was very weak. That was the problem. LOL
[youtube]http://www.youtube.com/watch?v=ZbE9-VCXT3M[/youtube]
Thanks!
Old 02-26-2013, 06:26 PM
Dirty_Vinylpusher
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A 17KG servo might steer that car if you run it on a smooth surface, but I would get a bigger one just to be sure.
Old 03-14-2013, 09:37 AM
polaco1782
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey guys, a little update here!
Got my new servo motor, it's a 24kg model made by blue-bird. Looks pretty good.
here it's infowww.blue-bird-model.com/en/servos/bms-l531dmg.html
Tomorrow I'm going to install it. It's the only missing part. I'm very excited to see the car in action!
Thanks!
Old 03-14-2013, 03:34 PM
jbooker82
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wonder if you could use a GoPed GSR40 clutch on that. Do the clutch shoes mount on the flywheel on that motor?
http://www.davesmotors.com/gt843
jbooker82 is offline
Old 03-16-2013, 06:55 AM
polaco1782
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, the shoes are mounted on the flywheel
That shoes might work, the original is this one:produto.mercadolivre.com.br/MLB-465219252-pecas-rocadeira-kawashima-embreagem-_JM
Contact Us Archive Advertising Cookie Policy
