Long frame XBE/5ive build
RE: Long frame XBE/5ive build
No vids as it isn't done.
I just got in the carbon fiber sheet in 2 days ago and made the center brace yesterday. I will post pics soon. I will be cleaning up the shock mounts as well. should be running soon. I will be running the toro esc with this build for now.
#35
well I got it to run. the shocks need a lot of work. the shaft seals a shot! I have stiffer springs that will help, as soon as they get here. I love the power but it's really hard to drive with this kind of power and shot shocks. I have worked on the body and it looks great. I'm saving it for the up coming parade so it will be running with out the body until the parade.
#39
So you can see that a lot of carbon and also a Kaiser t6 aluminum frame was added. here is a video that shows pictures of the build.
http://www.youtube.com/watch?v=DBcf9etjSKw
#42
Getting it right, finely!
I'M BUILDING A PROPER SHOCK!
What you see, is 4 rear Team Losi shocks being built. Still needing some parts. The adujustment collars and some seals that didn't make it in the rebuild kit.
I will be adding an carbon brace that goes across the shock mounting studs so that they don't flex as well.
#44
