I need Help with the front end of my Baja5b!!!
To make a long story short I clipped a fence post with my right front wheel. Well That broke the right front shock and the lower a-arm.
I removed the 4 front end chasis screws on the bottom of the front end that hold the front end in place to get a little clearance to remove the A- Arm clips (just the ones closest to the frame so I could slide the pins out the front. I got all the front end components together, but I just "CANNOT ALIGN THOSE 4 SCREWS THAT HOLD THE FRONT END IN PLACE" Again they are on the bottom of the front end. 2 are cover covered by the small plastic skid and 2 bolt up threw it.
I would sincerely appreciate any help!!!
