Replacement Clutch shoes for off brand baja
NY
I've been working on a custom body for my kalee baja truck, and while at it decided to repaitn the plastics to match.
Ended up pulling the clutch since I was already almost there, only to find the shoes are shot. Are the stock HPI clutch shoes worthwhile, or are there better one's available for the same price range? Also, does the higher spring make enough difference to be worth, or is it more trouble(replacing the spring while at it)?
P.S. Pictures will be coming once done with body and paint.
P.S.S. I did try the search function, but either I'm screwing it up, or my computer is because I ended up with a lot of intro on the clutches for nitro engines.
