Rampage xb throttle servo
I have a question I'm hoping to have answered. I would like to know when I replace my throttle/brake servo doing just plug it in and go or do I have to set it up somehow? I'm pretty new to the 1/5 gassers
You have to make sure that the radio (or the actual channel) is set to zero on the trim, then the servo will center itself when you turn on the transmitter. Then you mount it on the car and when it's done, you might have to adjust the trim on the transmitter to get the servo to stay where it used to before you swapped the servo.
Oh no I've been into RCS for years and have a little collection but when it comes to 1/5 scale gas this is my first and thank you for all the info I'm checking out some servos but I'm not to sure if the will fit.
