RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Revo XL builds
Old 11-10-2014, 09:37 PM
  #51
twissted
twissted's Avatar
I thought I would show another cage mod that should have been done with the cage in the first place!
I will paint it black when its installed properly.
Old 11-11-2014, 05:10 PM
  #52
twissted
twissted's Avatar
Looks like it should have been there from the start.
Old 11-12-2014, 06:14 PM
  #53
twissted
twissted's Avatar
So these show the monster servo to turn the 7.55'' tires and also shows the summit 2 speed trans in place.
Since this is going to be a rock crawler and a desert beast The 2 speed trans and larger servo are need to perform at it very best. My goal with the Yeti XL body, is to make look great and perform better that the Summit or the Yeti XL. I think that the 2 speed trans with the Robinson Racing slipper chutch and large steering servo, that it I will be way ahead of the game. Also the Traxxas diff gears from the E-revo should help with the big 4074 2150kv sensored motor thar is going in. I will be running 4s to keep parts from breaking but on some days 6s will also see some duty.
Old 11-12-2014, 06:25 PM
  #54
twissted
twissted's Avatar
Here is a picture that shows just how big the steering servo is compared to my Revo/DBXL build.
In this one you realy can see the tire and wheel base differance. 18'' and 22''
Old 11-13-2014, 01:14 PM
  #55
twissted
twissted's Avatar
I did a spring upgrade on the rear Of the revo/DBXL build.
There made by r/c Raven.
Old 11-15-2014, 10:24 AM
  #56
twissted
twissted's Avatar
https://www.youtube.com/watch?v=6tmcuzLQo0w
Old 11-17-2014, 04:28 PM
  #57
twissted
twissted's Avatar
Based on these specs can anyone tell me what resistor is needed to run 4 bulbs on 3s or 12 volts?
SPECIFICATIONS:
Source Material:InGaN !
Emitting Colour:10MM POWER WHITE 1W LED
LENS Type:Water clear
Color Temperature: --
Luminous Intensity-MCD: Typ: 390,000 mcd
Reverse Voltage:5.0 V
DC Forward Voltage: Typical:
DC Forward Current:300mA
Viewing Angle:40 degree
Lead Soldering Temp:260°C for 5 seconds
Old 11-22-2014, 11:33 AM
  #58
twissted
twissted's Avatar
We finely got some snow!
Old 11-22-2014, 04:31 PM
  #59
twissted
twissted's Avatar
Remember these?
Well there still in the works but to save money I will be going with the BFG Krawlers insted of the Micky 3.8" BAJA MTZ
I save 30.00 and I like the look and size just as much. In fact the size is better for what I need from them for the Desert Buggy Build.
Old 11-22-2014, 04:32 PM
  #60
twissted
twissted's Avatar
Also ther is going to be a big change in plans for my Yeti XL chassis that I was using. I will be changing it to Carbon fiber I plan on cutting a new Vantage chassis and adding carbon fiber to get the lenght that I will be needed. Also the diffs are going to be beefed up by using Losi LST 2 diffs with thge aluminum housings.
This will then be able to take big power and large tires with no problems Hoping to make it light weight and bomb proof at the same time. I still plan on mounting the Hitec HS-5575MG servo. I want the build not only light as possible but strong as possible. Should be a bad boy RC Desert Buggy! I have been looking on the tower web site and the cage pieces can be had. I may go that route and and the factory plasic pannels later. I will make my own aluminum pannels and go from there. I should have the parts I need and have the build ready for Christmas. Time and money will tell. I'm trying to find Vantage carbon A-arms if anyone knows of any.
Old 11-22-2014, 04:33 PM
  #61
twissted
twissted's Avatar
After looking at the Losi Muggy online. I think that it will be my next project for what ever cool offroad body comes along. I will use a carbon chassis to get the wheel base that will be needed to make it happen. Should be a wild build.
Old 11-25-2014, 05:36 PM
  #62
twissted
twissted's Avatar
I just placed a order with RC4WD for the new 3.8 Beadlocks for the Desert Buggy build. I will welcome 2'' wider stace that these offer. They look good also.
Next payday I'll get the BFG Krawlers!
Old 11-30-2014, 05:11 AM
  #63
twissted
twissted's Avatar
https://www.youtube.com/watch?v=34AtcLq3iH4
Old 12-03-2014, 12:46 PM
  #64
twissted
twissted's Avatar
Old 12-04-2014, 02:43 PM
  #65
twissted
twissted's Avatar
https://www.youtube.com/watch?v=JNSVCvK6Y88
Old 12-05-2014, 02:04 PM
  #66
twissted
twissted's Avatar
I ordered the 3.8 BFG Krawlers today. I also picked up a new esc to try. It's a SkyRC Toro-8S 150A ESC for 1:8 sensored/sensorless RC 2-6s LiPo+capacitors that I found on ebay. It's being shipped from china so it will be awhile before I see it. The tires are from NY so they should be here in a week. I got a smoking deal on them 55.00 set of 4 shipped!
Old 12-08-2014, 04:03 PM
  #67
twissted
twissted's Avatar
New Shoes!
Old 12-15-2014, 09:34 PM
  #68
twissted
twissted's Avatar
I moved the lipos forward 3'' to get more performance out of it.
Old 12-22-2014, 06:25 PM
  #69
twissted
twissted's Avatar
I'm stepping up in the Video Department! I will start mounting is most of my videos now. I will still have a head mount camera going also.
Old 12-24-2014, 10:18 AM
  #70
twissted
twissted's Avatar
Old 12-26-2014, 09:26 PM
  #71
twissted
twissted's Avatar
https://www.youtube.com/watch?v=fluW_2VkyJs
Old 01-05-2015, 07:25 PM
  #72
twissted
twissted's Avatar
This is on my other build that uses a Yeti XL body. So the wheelbase is only 18.5''. But this shows how I'm setting up the 2 speed trans for both Desert Buggies.
Old 01-24-2015, 10:38 AM
  #73
twissted
twissted's Avatar
The front lite buckets that are from the Losi 5ive is now a functioning set of 10mm lites with flashlight lens to get the look I wanted. I will be using resistors to keep the voltage as it should using a 2 cell liopo battery.
Old 01-24-2015, 11:08 AM
  #74
twissted
twissted's Avatar
