RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
AoWei 1/5th Scale 26cc Yama Petrol RC Buggy to electric
Reply
Old 04-12-2016, 04:21 PM
thetonymul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AoWei 1/5th Scale 26cc Yama Petrol RC Buggy to electric
hello im new to 1/5th scale so i bought a cheap AoWei yama buggy but after 4 years of sitting i want to convert it to brushless and sadly the only kit i have found is for a fg 1/5th scale i think it will work because the gear looks the same but thats why im here to ask for help thanks
i want this to fit on this heres a pic of the gearbox
ID:	2157093   Click image for larger version
thetonymul is offline
Old 04-12-2016, 05:08 PM
Maj_Overdrive
Maj_Overdrive's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well from the pics you provided of your buggy it looks like an FG clone. So that conversion kit you posted for FG's should work. FG themselves also have a conversion kit, FG 5862. The FG kit will also take a true 1/5 58mm diameter motor. It should be noted that the FG kit says that some holes will need to be drilled in the chassis, it may be the same with the kit you posted, not sure as I didn't look for it.
Maj_Overdrive is offline
Old 04-12-2016, 05:21 PM
thetonymul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok if i can get the motor mount what motor/esc would you say to use
Old 04-13-2016, 09:52 AM
Maj_Overdrive
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like I said, I couldn't find a link to the exact motor mount you posted, only the one made by FG. If the one you posted can take a 1/5 scale 58mm diameter motor then there's no reason not to consider it.
Either way your truck is heavy, over 20lbs. Anything less than a 58mm diameter by 90mm long motor is going to be struggling to push that much weight and heat up too much unless geared for a low top speed. The big 5890's have the torque and power to push that much weight and not heat up. As far as brands I'd stick to Castle or Leopard, they're the proven performers in 1/5 and 1/6 scale vehicles.
Sorry but but I can't really help you what voltage and kv to run. Your vehicle is on the lighter end of the big boys and I've seen some people run 6s in similar vehicles. If it was me I'd go 8s, that's what should be in there and then you know you'll have all the power you'll need. But I also like lots of power. Either way you need to go with a 1/5 esc and they're all 8s capable so it's there if you want it. Again I'd stick with Castle or the new Hobbywing Maxx5 which has much better support than any Turnigy, Toro or other Hobbyking brand.
If you provided me with the exact tooth count of all the gears in the drivetrain as well as the tire diameter and voltage you want to run I could do some gearing calculations to help figure out what Kv to run and gearing. But I need to know all those things.
