Fg f1 help !
Fg f1 help !
Hello, its been really tough finding parts for this car, i have an FG F1 sportline with the Solo 108 engine.
its been bogging out pass half throttle, so I decided to rebuild the Carb, ordered the parts to rebuild the HDA 156 carb.
cleaned it with carb cleaner , put every back and now it wouldn't even sputter.
checked everything I could, fuel line, replaced fuel filter, replaced spark plugs, theres little sparks on the plug when i take it out.
so i came to conclusion that I think the ignition is bad.
Does anyone know if I can put an Ignition for Zenoah? will that work? they Charging $96 bucks in the UK for this part, if thats the case, might as well upgrade the engine to G260.
if I went that route, what else do I need to make sure that Zenoah is plug and play?
Throttle link?
Can I use the carb or the Clutch that comes with the motor? is there modifications needed to fit that motor?
thanks in advance.
Throttle link?
thanks in advance.
