RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Hpi Baja 5B only runs with choke on????
Reply
Old 01-05-2018, 03:58 PM
Marcumbent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hpi Baja 5B only runs with choke on????
Hey there Ive got a HPI Baja 5b and itíll start with choke on but if I begin to remove choke it starts to rev up just like Iím giving it fuel but actually Iím not. While itís running if I do give fuel it dies. Carb jets are set factory and idle screw is all the way down. And seems like itís awfully rich too. Any help please????
Marcumbent is offline
Old 01-05-2018, 08:34 PM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What happens after you open the choke and leave the throttle at idle.....does the engine continue to rev up and then die ?
If so that sounds like an air leak.
flyinwalenda is offline
Old 01-05-2018, 08:43 PM
Marcumbent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No it doesnít die it just keeps on reving up. And throttle is actually all the way down
Old 01-05-2018, 09:10 PM
flyinwalenda
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Checking the obvious. Are you sure the throttle channel is not reversed .,,,,can you see if the throttle plate is actually open or closed when throttle position is low?
Old 01-05-2018, 09:52 PM
Marcumbent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The throttle plate is actually closed
Old 01-06-2018, 04:42 AM
flyinwalenda
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Float may be stuck open flooding the carb/engine but the engine still needs air to burn the fuel. If the air isn't getting in through an open throttle plate then it's getting in through a leak somewhere.
I would pull the carb, dismantle and clean it and check the fuel pump and metering diaphragms or better yet get a rebuild kit and change the float,spring, diaphragms, gaskets, etc...
Old 01-06-2018, 05:39 AM
Marcumbent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Itís got a brand new carb and it didnít help any. I just put that on yesterday. So Iím assuming that there wasnít anything wrong with my other one.
Old 01-06-2018, 07:02 AM
Marcumbent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I donít know if itíll help any but Itís a 29cc Zenoah ported with modified piston with a DGI reed valve
Old 01-06-2018, 04:14 PM
flyinwalenda
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So , has this truck ever been running while in your possession?
If so, when did it start acting like this and what happened to it leading up to this ?
Old 01-06-2018, 10:01 PM
Marcumbent
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey I got it running just what you had said earlier an air leak. I had bought it that way got a heck of a deal I was hoping it wasnít nothing major. Thanks
Old 11-03-2019, 01:01 PM
tuclai
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi how did you determine the air leak? What did you end up doing? Having exact same problem.
tuclai is offline
