RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Servos glitch once engine starts
Reply
Old 12-03-2018, 09:37 PM
seansco999
Default Servos glitch once engine starts
Hey all,
On my 1/5th scale Redcat Rampage MT, I am having trouble with my servos glitching once the engine is tarted. When the engine is off booth steering and throttle servos are 100% normal. As soon as i fire up the engine they both start glitching (seems like it could be RF issues). I do have 2.4GHz radio frequency and am using spektrum receiver. Sometimes when I try and give the truck about half throttle, it will go straight to full throttle and get stuck there for a few seconds. I got this truck a couple months ago used, and previous driver indicated no such problems. I did put in the spektrum receiver, killer bee kill switch, and a new spark plug.
I have checked the servos, they are great and no issue there. I think there is some RF coming from either the spark plug, somewhere else on the engine, or possibly the killer bee kill switch?
I dont know what would cause the servos to jitter so bad, and what would also cause them to randomly go full throttle and stick. RF is my only thought.
I plan to install the old kill switch back, tighten down the spark plug, and potentially go with a different receiver if this all fail.
Please lend me some ideas, or if you have encountered a similar problems.
Sean
seansco999 is offline
Old 12-04-2018, 05:30 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check to make sure the plug cap is securely seated on the plug. If the plug cap is metal, it needs to be firmly locked into the spark plug.
Also, you did use a resistor spark plug, right?
1QwkSport2.5r is offline
Old 12-04-2018, 07:51 AM
seansco999
Spark Plug is (Type H-CMR5), I dont know if this is resistor or not. (new to gas models, only have had nitro and brushless before) I will re-seed the spark plug tonight and and make sure the plug can is secure
Old 12-04-2018, 08:46 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it’s a true NGK CMR5H (#7599), it should be a resistor plug. Check the plug cap and also check to ensure the receiver is as far away from the ignition as possible. Is the engine CDI equipped or magneto?
Old 12-04-2018, 08:44 PM
seansco999
While troubleshooting I switched out my Hitech analog servo for a Savox digital one. All the noice is gone and everything seems to be working as normal
Old 12-04-2018, 11:06 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While not usually necessary, I’m still glad you found a solution.
