*CRAZY* 1/5 CAR **help**
[:-] I have a bergonzoni and every time y try to run the car ,i get radio interference and it is impossible to run the car.
i have been told that you get it from the engine.if any body knows how to resolve this problem.please help
RE: *CRAZY* 1/5 CAR
If that is the issue a resistor spark plug cap would help. I use the NGK LBO5E 9not sure if this cap will fit your plug or not though). But I had the same issue, mine was either the channel I was on or the radio. Does it have interferance every where you try to run it? Do you run it in the same area every time?
RE: *CRAZY* 1/5 CAR
If ya have any graphite on the car does ya ariel wire touch?This is a good contributer to glitch,used to happen on me 1/10 scale
good luck.
Voo.
good luck.
Voo.
RE: *CRAZY* 1/5 CAR **help**
there is only one solution that realy helps, you must use a fm radio ore better a pcm radio, it´s not possible to change the electronic ignition ore the sparkplugcap to make it free of problems for your am radio.
Mr Bergonzoni
Mr Bergonzoni
