FG Bearing sizes? (Leopard)
What is the bearing sizes on the FG Leopard with an Alu rear Diff?
I know that the Wheel Bearings is standard 608zz bearings.
But what size are the Diff. bearings and the bearings for the Drive Shaft?
I plan on using standard Rollerblade type 608zz ABEC 5 bearings for my wheels. No matter how much I tune my Engine, I don't see that I can get the Wheel RPM anywhere close to 32000 rpm. (1025 km/h or 640 mp/h with 17 cm dia. wheels)
Happy driving from Greenland
Jesper Rex
Jesper Rex
RE: FG Bearing sizes? (Leopard)
15x28x7mm for the differential.
For the differential shafts there are a bronze bushing 8x12x5 mm and a needle bearing 8x 12mm (I'm not sure about the width) per side.
Well I could just read the spare parts list that I found on the FG Home page. I just did not expect it to have the exact sizing on the parts list, but I was wrong.
Here is the bearing sizes I have found:
Clutch: 10x22x6 (FG# 6040)
Middle Axle: 10x19x7 (FG# 6036)
Alu Diff: 15x28x7 (FG# 8496)
Jesper Rex
Jesper Rex
