bearings
bearings
Hi i need some help. i'm changing my front end over to alloy. how do i remove the bearings from the hub carrier? i have the bearing removal tool but i can't figure out how to use it? do i use the 3 little attachments that come with the tool? any help or pictures would be appreciated.
thanks shymot
thanks shymot
AB, CANADA
RE: bearings
if you have the little and the big tool you need to use the big tool and select the attachment that fits into the middle of the bearing and press it out. the bearing will push into the large opening of your tool. easy and quick.
RE: bearings
shymot,
I'm in the middle of the same upgrade.
Luckily I was putting new bearings into mine, so i was able to just "punch" out the old ones. After installing the new ones, I see when i need to remove them for cleaning... I'll be in trouble!
I just press the new bearings into the alum hubs with a vise and 2 blocks of wood
Where can this bearing tool be bought?
AB, CANADA
RE: bearings
did ya get em out, you can try a little heat to that always helps. sorry i can't remember the exact sequence to get em out with the tools, but you'll figure it out. i am still searching for mine. lol.
RE: bearings
I changed my hubs today and it was extremely easy without any specialist tools.
I just carefully levered them out with a screwdriver. They are not seated tight enough to need a puller. Just put the screwdriver in the middle and carefully work them out a little at a time, makingsure to work all the way around the bearing.
May well be a different case when getting them out of alloy hubs but the plastic ones are no trouble at all.
RE: bearings
thanks dubby, i found out i could wiggle them out using the axle. but i screwed them up putting them in the alum hubs. oh well christmas present for me
thanks for everybody's help
