MARDER MISSES ON FULL THROTTLE
My Marder misses on full throttle. I've changed the plug, stripped and cleaned the carb and fitted a new gasket. The carb is set at the factory settings.
I've fitted a K&N filter and a samba exhaust , is this causing the problem?
RE: MARDER MISSES ON FULL THROTTLE
Deltron63 your`e running to lean mate stop before it all goes pear shaped.Turn the high speed screw(the one to the left marked H) one 1/8 to one 1/4 anti clockwise at a time till it runs sweet if this dosn`t cure you have one major air intake leak.
if its lean i thought you wanted more fuel ? so turn the needle out (anticlockwise (left))
not in (clockwise) that will make it even leaner ?
what it to be then chaps, richer or leaner?
i think i should start of rich then lean it out a bit.
on tick over and normal throttle it fine, only when i give it the big one it spluttters.
ORIGINAL: ibstar
Yes first go anticlockwise to richen the mixture as this will do the motor no harm.Go leaner on an already lean motor and it will sieze/break/cost money to fix.
Go anti-clockwise on the H needle first this will richen the top end but will not damage the engine, if it runs worse go clockwise this will weaken/lean the mixture.
Banned
ORIGINAL: dubby
your best bet is to ignore me
That's what happens when you take those magic mushrooms!
hi i had the same problem
so i changed head gasket,carb gaskets and insulator block,,,
did the job ..... the way i checked it is set needle valve back to factory set and if u have to richen the low end to get it to tickover slow enuf u have defo got an air leak
I had a similar problem after changing the air filter.
Had not put the carb gasket in place properly
Now if its the cy engine you have, it might need the carb cleaning out
The latest up date on the missing:
I warmed the engine up, took it for a high speed pass and the vioce in the back of my head said " take it over the big jump". I shouldn't have listened. it came down on it's arse and did loads of damage!
It should be fixed by the weekend, so i'll try again.
