RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
MT Tires Medium vs Hard
Old 02-25-2005, 02:25 PM
ricok
ricok's Avatar
Default MT Tires Medium vs Hard
I've ordered the following from FG-Modellsport-Vertrieb in Germany:
1. Monster-Truck RTR (G260RC/04)
2. Gear Cover (FG6423)
3. Shock oil (500pce) (FG6510/5)
4. Roll Bar (FG6180)
I need to make a decision on the following. As I understand the MT comes with 2 medium and 2 hard tires. Siegfried (owner) gave me the option to choose my tires' hardness.
1. Would you recommend that I go for 4 x medium tires?
2. Does the RTR version comes with foam inserts?
3. Must I ask for the tires to be glued or not?
I was thinking that if the RTR version comes with the foam inserts, then I don't want the tires glued for I want to decide if I'm going to use the foam inserts or not. If it does not come with the foam inserts, would you recommend I get some. Has anyone experimented with the foam inserts?
My order is currently on hold, for I have to give Siegfried answers on the issues mentioned above. I'd appreciate some advice. Thanks.
Old 02-25-2005, 02:38 PM
MJT
MJT's Avatar
Default RE: MT Tires Medium vs Hard
1. I would recommend you to go with 4 x Hard tires. I have 2 medium and 2 hard. I have mounted the Hard in the back, and the Medium in the front. The Medium tires are to soft for my opinion - if the car are placed at the same spot for 24 hours or so, the tires will change form and are not completely round anymore - therefore, when my car is put away for the week, i put it on a stand, so the tires dont touch the ground.
2. I thought that FG had gone away from using inserts? I know there are no inserts in my MB nor my brothers MT - the reason is that the inserst were getting moist, and were acting crazy. The FG's we have were not delivered with inserts (not RTR though, but I dont think it matters?)
3. Dont ask for inserts, but ask for them to be glued. My tires were glued when the MB arrived - it is nicely done, and they have made a small hole, so the air pressure can compensate for cold and warm weather.
The Spur gear protection cover is a very good investment.
What you should also consider, is to order the reinforced differential tube which is 3 times thicker than the normal.
Also invest in some diff locking grease, which lock the differential - its cheap and very good - your MT/MB acts much more power full with 100% traction on both wheel.
Old 02-25-2005, 02:48 PM
ammdrew
ammdrew's Avatar
inserts are not avalable yet.
Old 02-25-2005, 03:04 PM
ricok
ricok's Avatar
Thanks for the advice MJT. I thought that the medium tires would maybe make the truck less bouncy? I don't know? Right, I'll ask for the the tires to be glued then without the inserts. I'll make the holes in the rims afterwards myself. Thanks again.
Old 02-25-2005, 03:41 PM
MJT
MJT's Avatar
From stock, the MT is a bouncy thing. No doubt about that. But the trick is, to change the oil in all 8 suspension cylinders - the standard oil is thick as glue, and very bad for use in the MT. Use som new oil with viscousity 200 - then the MT will be as good as the MB.
Old 02-25-2005, 07:10 PM
kirkieboy
I took off all of my tires since I bought them. How do you know which ones are the hard and which ones are the medium? Is there a mark or something?
Old 02-25-2005, 07:36 PM
FGUK
Banned
Lick them, the hard ones are bitter and the mediums are sweet.
Old 02-25-2005, 07:55 PM
kirkieboy
Nope, they all taste like rubber!!!!!! [:'(] damn you FGUK!!!!!!!!
Old 02-25-2005, 08:08 PM
FGUK
Banned
Now the sensible answer..........
There should be a small (4mm) circle on the side of each tyre with a letter in, M for Medium and H for Hard, apart from that, it will be fairly easy to tell if you just feel each tyre.
Old 02-25-2005, 10:15 PM
kirkieboy
Thanks, now don't try to make someone lick rubber next time! LOL
Old 02-26-2005, 04:46 AM
chevyman_de
chevyman_de's Avatar
ORIGINAL: ammdrew
They are available and yes, they are in stock.
Old 02-26-2005, 04:15 PM
ricok
ricok's Avatar
Are their any other guys that have experience with the tire inserts?
