Firehammer help needed
I am looking for the pc that mounts the throttle linkage to the carbureator. it is like a small black pc that mounts with a single screw right in front of the choke lever. for some reason it stripped out and i dont see it on the list from duratrax. Maybe it is the same on alot of the cars, i am hoping fo i can get the pc soon. thanks in advance.
CA
RE: Firehammer help needed
ORIGINAL: DERF-54
PC? Need more info to help you out. I am not sure what you are asking for.
Fred
Fred
I had a hard time also
SD
I looked at Tower Hobbies and Hobby People and could not find the part you were looking for seperately from the carb. Sorry. Found this to be odd on Towers photo of the carb though. It appears in the picture (provided in the link) that the plastic part you are talking about looks metal in their photo. My firehammer part is black plastic as well. Can you super glue or epoxy it to the shaft? Of course that would be a last resort.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHKT3&P=X]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHKT3&P=X[/link]
My Feedback: (10)
you can probably use servo mount spacer from a touring car. They are used to raise the servo 1 or 2 mm off the upper decks. One of those should work fine.
