RTR Failsafe
RTR Failsafe
Anyone else had problems with the RTR failsafe?
Just been out with the car and every time it hit a bump bigger than a rabbit turd the failsafe kicked in (steered to right with slight brake applied), car ran fine when kept on flat ground.
On the few occasions the car flipped the wheels were juddering.
I was in the middle of nowhere at least half a mile from any source of interference
Almost forgot - got my first crack in the body shell..... I'm so proud
RE: RTR Failsafe
No idea what failsafe it is mate, just looks like a a servo cable with a knobbly heatshrinked bit in the middle.
I'll buy a decent one tomorrow.
RE: RTR Failsafe
Made sure everything was well connected at the time but it didn't help.
Think I'll get a better on/off switch tomorrow as well just in case that's the problem
RE: RTR Failsafe
local model shop (pegasus i'd guess) should be able to sort you out most here keep the gws (orange) failsafes. you want the more expensive one £15 ish i think, does low voltage and lost signal.
