brakles fg mt
brakles fg mt
can anyone help got stard brake on rear and cable brakes on front off mt after about half an hour my brakes stop
working is it brake fade or is to do with servos
RE: brakles fg mt
Sounds like a screw came loose on the brakes. Had it happen to one of my F1's. Check inside where you can see the brake pad and see if one of the arms is loose. Most likely it would be the bottom.
