Bergonzoni GB clutch problems
NY
I got another Bergonzoni Bandit/Bull used that needs a lot of work and clutch was busted. Clutch bell spins but clutch is loose so placing a pin in the hole does not work. Any ideas how I can disassemble it.
Visit http://www.kalabok.com/ - Hobby Search Engine
ME
RE: Bergonzoni GB clutch problems
if you find some info let me know, mine is out of adjustment, it gets so hot it actually smokes when i'm running. I'm not sure on how to get it apart either.
NY
I got it!
I had to remove pull start cover and held the crank shaft with the socket wrench. It worked nicelly.
After I got the car I completely disassembled it as it was in pretty bad shape, owned by novice most likely. So I removed engine from the car and did some work on it as I did not expect it to work. After I was done I started it up and boom :-( clutch locked. Who ever was working on this engine before me did very bad job. I should of checked the clutch but did not. Screws came out and looked the trany, nobody even put thread lock on the screws. Well now its all tuned up correctly. So if you get used car ALWAYS check the clutch, otherwise it may cost you a bit.
