Un-dye wheels / wheel question
VA
I dyed my marder wheels with RIT Dye and I'm not to happy with the color. Does anyone know if your able to un-dye the wheels and get them back to the original white or am I S.O.L? If not does anyone know if the FG #6436 Wheel extension white, 2pcs will work on the Firehammer wheels. I need the extensions for the rear slick tires. Firehammer wheels are only $12 for two at Tower. Thanks.
RE: Un-dye wheels / wheel question
Not sure about the extensions. To remove the dye I would place the wheels in a pot of boiling water and maybe add 10% bleach if that does't work good luck with tower and the firehammer wheels.[sm=idea.gif][sm=drowning.gif][sm=drowning.gif][sm=drowning.gif]
AZ
The best you can hope for is to change the color. get some black rit dye and boil them for about an hour that should at least give you acceptable looking black wheels
