Spark Plugs
VA
Spark Plugs
I want to get another spark plug for my Marder Race with the G260 and I wanted to know what is the best plug to get. Most people on this forum go with the irridium spark plugs. I went to sparkplugs.com and cross referenced the RZ7C stock plug I'm currently using and it suggested the Denso Iridium plug stock #5384 part #IUF24 for $11.99. Is this the best plug to use? Thanks.
AZ
RE: Spark Plugs
This is the plug most people will use as a replacment:
NGK CR8HIX
http://www.davesmotors.com/store/product622.html
Make sure whatever you get it is a resistor plug.
NGK CR8HIX
ID
RE: Spark Plugs
I've run the champion, NGK, and Denso. Both the NGK and Denso seem to run a little better than the champion but the difference is small and might have just been better tuning on my part that particular day. I can't tell any diff between the NGK and Denso so since the NGK is cheaper, that's the one I'll continue to buy.
