Cable brakes
ON, CANADA
RE: Cable brakes
If you do get them you'll need the alloy uprights which let you place the assembly in the back. I have both sets and when I tried to put them on the front I noticed the shocks are in the way of the cable route. Sometimes the cable goes beetween the springs!! If you zip tie the cable it binds a bit so I wouldn't do it. I think the number is 6103/4 but the catalogue shows the same number for both uprights so be carefull if you do order.
