Starting probs
Starting probs
Can any of you engine boffins help.
I've got a spark at the plug, fuel is getting through and the engine will fire for a nanosecond if idle is set as high as possible.
What could the problem be?
RE: Starting probs
thanks for the suggestions.
there were a few air bubbles in the fuel tube, i'll try again after replacing the tube.
carb was stripped and cleaned last week after the car went for a swim in a ditch....... been running fine since though, until today.
choke on or off i get the same problem.
thanks again
thanks again
RE: Starting probs
Try replacing the plug. You may well have a spark when it is out of the engine, but it is not unusual for a plug to break down under load. go for the easy things first.
Ade
Ade
RE: Starting probs
thnks but tht ws the first thing i tried
got cider in keybord nd it's spreding hence few dropped letters nd no shift key lol think i my hve discovered the origin of text spek
UT
RE: Starting probs
ORIGINAL: Pigsmightfly
thanks again
thanks again
