Homemade Truck
Homemade Truck
Hi I am looking to build my own 1/6 or 1/8 truck with a weedeater engine but I dont know a good site that would sell a chassis that is for that anyone have any sites where can buy stuff to make homemade trucks like this? In US also.
RE: Homemade Truck
I don't know if I would call it easy, but if you have the time it can be quite rewarding to build from scratch. I have been working on one for some time now and it's starting to look like something finally. I have access to some machinery at work in my off time, so that is my biggest help. I started this because I was always dissatisfied with plastic kits and little or no flexibility to make big changes. The pictures show the chassis sitting up on a jack because there are no springs yet. It is 1/6 scale, with a 19" wheelbase.
If you want to do it yourself, I can tell you it's awesome. You can pretty much design it however you want, and The only limit is your imagination. Good luck!
Banned
My Feedback: (10)
WI
RE: Homemade Truck
Good Start.
MY 1/5 MT has a 22" wheel base 32" wide and 45" long 22" tall with 12"x8" tires.
2 Skellenger quick change rear ends
3 hp motor with a reversing transmission
4 wheel drive with 4 wheel steering
All Aluminum chassis
My Feedback: (7)
KS
RE: Homemade Truck
ORIGINAL: Superheat
RE: Homemade Truck
Yes, it is modeled after the Clodbuster (Clodzilla 4 chassis, actually). I wanted to make something longer and more stable, as well as all aluminum. It's been taking forever, but the reward will be seeing it in action!
RE: Homemade Truck
mbbaj2001
Good Start.
Good Start.
RE: Homemade Truck
What size is your weedwacker engine as i am get a 34cc weedwacker engine tomorrow for £46.61 which is on sale to power my LMP car does anyone know what Hp it should produce.
Banned
My Feedback: (10)
WI
RE: Homemade Truck
Yes I welded the tube chassis. This was my first attempt at welding a tube frame. More work (over 50 hrs to make) than I thought but proper planning made it easier. I still prefer the box frame construction with aluminum (30 hrs manual machine with CNC alot faster). The only problem I see with your truck is do you have enough room for the motor and electrics. The weed wacker engines are big and the truck is bigger than a clod so I hop you put larger bearings in the axle tubes. I had problems with the bearing blowing out. Don't use the miniature size bearings found in most 1/10 or 1/8 scale cars.
RE: Homemade Truck
It's going to run on 2 HV-MAXX Novak brushless motor systems; 1 for each axle. The stock Clod had a motor on each gearbox, but I wanted to keep the axles free of any clustered parts so they will sit up inside the cab of the body and will be connected to each diff by way of driveshafts which can extend/retract as the suspension moves. The motors will be above the top of the chassis as you see it in the picture, so there is plenty of room.
The axle tubes have 6x12mm bearings and Ofna 1/8 scale steel differentials inside. I don't believe the truck will be terribly fast, as I'm gearing it to crawl.
I have no access to CNC equipment, so everything has been manually machined so far. Nice job on your frame...I've always liked the welded-tube concept.
PA
RE: Homemade Truck
ORIGINAL: Superheat
I've been thinking for a long time about building a large scale clodbuster style monster truck. Problem is that i dont have access to a machine shop so making axles is where i get stuck.
RE: Homemade Truck
ORIGINAL: mbbaj2001
Should have used b a GAS engine. I have moved away from charging electric powered vehicles. Electric will never preform like gas.
RE: Homemade Truck
ORIGINAL: drevil
That is a really nice setup. Are those axles total custom made? Where type of gears did you use in it. Ever think of making a few sets of those to sell?
Banned
My Feedback: (10)
WI
RE: Homemade Truck
Yes, I have designed a lot of part for my trucks and made all my own parts for them and have my own machines to do it. All parts are done manually but I can make them CNC later.
