Lights on marder or leopard race buggy
PA
RE: Lights on marder or leopard race buggy
Absolutely. There are various companies that sell lighting for r/c cars or lights that can be adapted for r/c cars. OR you can make up a custom set for yourself.
I once made a custom set of lights for a clodbuster out of a small set of lights i bought at a party store.
EDIT: http://www.rcmods.co.uk/
PA
You would need a generator of some sort. They sell something like that for r/c planes that can power something or recharge the battery but i doubt it would be worth the trouble as a set of small lights will run for quite a long time on just one 9v battery. OR if you have a big enough reciever battery you could run the lights straight off that.
AB, CANADA
I made my own light design .. using very very bright leds... and flashlight bulbs.. not exspenxive to do.. but through a company it is.. if you have an idea of what you want let me know.. maybe I can wire something up for you.. here are some pictures of my monster beetle.. I run the lights off my receiver battery... they draw very little current ..... Garnet
AB, CANADA
Here is a picture of the front.. I used purple leds for that.. the back leds are 1 watt superflux leds... let me know if you are interested... or if any one else is... Garnet
UT
PC Case lights are dirt cheap ya get like 5 packs of 5mm lights for $3.25 Low voltage and bright too. Also in UV...For that glowing affect hehe
Pack of 4 x 5mm blue LED
NOT RETAIL PACKAGED
Voltage norm 3.0V - max 3.3V
Brightness 3000 - 4000 mcd
Usage
100 Ohm resistor for 5volt supply
470 Ohm resistor for 12volt supply
[link=http://www.coolerguys.com/caselighting.html]PC Lighting[/link]
NOT RETAIL PACKAGED
Usage
You could also get one of the New Bright RC cars/Trucks from Wal-Mart and use them. I gutted the body out and just use the shell for my MT and power the lights with a 9 v battery housed in a separate box.
WI
You guys drive at night? In the dark?
I've driven my cars in well lit Walmart parking lots, but not in total darkness.
Me too scared to slam into something.
PA
Yea i rarely run my r/c at night anymore but thats because i dont want the neighbors calling the cops. Back when i had a bullhead (clodbuster) that i put lights on i used to run it at night all of the time. Although it was usually on the street with lights, sometimes i ran it in a totally dark back yard and one of the best times i ever had with it was when i brought it to the shore with me and ran it at like 2am on the beach.
Come to think of it maybe the next time i goto the beach i'll run the marder on the beach at 2am until the cops come...lol...then again maybe not
Every once in a while I'll crank up the MT and send it across the street onto the Golf Course. Don't want to get too close to the ponds though. Not worried about the gators, just worried that I might not see the waters edge in time to turn or stop. As long as I do not drive it on the greens or sand traps and just stay on the fairways, I don't think they would mind. With the Hummer body which has headlights and tail lights it looks pretty cool.
