Zenoah G26 cut out question on FG Beetle
Hi there,
I bought a second hand FG Marder Monster Beetle recently and I have been having problems keeping the engine running. The engine starts ok but then runs for about 15 to 20 seconds before it dies. I can rev the engine or just leave it idling and it runs for about the same amount of time. I've looked at the plug, looks fine. I dismantled the entire carb and cleaned it - made no difference. I have also tried changing the mixture needles but the problem remains. It almost seems as if there is a fuel blockage but I can see there is fuel always running through the clear plastic primer while the engine is running.
The engine is a G26 (red spark cap) with a big bore kit 27cc and a ADA Racing JuiceBox.
I wonder if the "Juice Box" is causing the problem? I have no idea how this gadget works.
Any advice would be much appreciated.
RE: Zenoah G26 cut out question on FG Beetle
anything to do with engine trouble/tuning please contact www.sbracing.co.uk they will tell you whats wrong when you explain? they really know what they are doing and get the thumps up from me
NY
Spudtoo post a pic of the engine. Maybe the box might be backwards? Just a thought !
I'll compare it to mines, we seem to have almost the same specs. engine-wise !
