info about the FG 1/6 Scale gas monster truck
Hi there i just got a new FG 1/6 SCALE gas rc monster truck but what i need to know what would be a good Complete Radio control system with servos for steering and for throttle & brakeing if you can help me on this let me know thanks
RE: info about the FG 1/6 Scale gas monster truck
General requirements would be..
A 3 channel FM transmitter, stick or steering style, with channel EPA and trim settings
3 channel receiver with low level battery and transmission failsafes ie Futaba R113P
At least one high power quarter scale steering servo, or perhaps two
One standard size high torque servo for throttle/brake
LED battery monitor
Switch
Battery (5 cell sub c) 6V with receiver and charge leads
I personally have Futaba 3PK RX & TX set, 40mhz FM PCM, two Hitec HS-705 MG (metal gear) for steering, Hitec HS-645 MG for throttle/Brake, Robbe battery monitor, waterproof switch.
Other good setups would be Multiplex Rhino and Multiplex Power.
Futaba 3PM PCM also (most features of 3PK)
LED battery monitor
Switch
MI
ORIGINAL: polkcountyguy24
FL
ORIGINAL: Doahh
By the way FYI:
ESC are for electric cars (electronic speed controller)
By the way FYI:
ORIGINAL: Mad Wax
EPA is End Point Adjustment...... there is nothing in his post about an ESC.
i agree, decent radio gear is a must before alloy and other hop ups,see so many marders and other fgs on ebay with futaba attack transmiters/receiver package (£25),2 crap servos and a £10 failsafe - i wouldnt trust a £40 setup in a £600+ model
Banned
ORIGINAL: Acs_guitars
ESC??
ORIGINAL: Doahh
By the way FYI:
By the way FYI:
ORIGINAL: Mad Wax
I use a sanwa Gemini II FM which is a stick type handset (not wheel/trigger) which allows me to set the EPA on the servos too & multiplex servos, Rhino Digi 4 for the steering & power speed for throttle, they work great with no probs :-)
as for fail safe, ive not fitted one (yet) as ive heard many different storys about them, some people say they have done the opposite of what they should do even though they were setup correct & some say theyre great, so atm im holding off, what i do want though is a audible alarm that will sound when my reciever batterys are getting low :-)
ORIGINAL: rctruckz
I agree with R C M a good radio is a must the cheap futaba/ acoms radio just dont cut the mustard. I have recently converted my KO 2000r to accomodate the spektrum unit. If you are planning to use truck in a crowded environment the spektrum unit may be worth considering. Also as good a servo's as you can afford, as if you upgrade the truck in future which a great deal of people do particulary the brake system you will need servo's with good torque.
PA
yea i dont have a 5 scale YET but i also recomend u spend ur money on really nice radio gear. i already have a m11/spektrum and it is promising! but again if u dont want that much of a radio get a m8 or a jr xs3 pro
jr line of radios are really good for beginners. i didnt know u had to have 2 large steering servos? thats like $250 right there!
