bad alloy front hub
WA
bad alloy front hub
I bought some new FG alloy front uprights with arms I went to install the bearings one side went in no problem the other side I'm telling you the opening isnt big enough for the bearing....is there a bad batch of uprights going around?... ie honed to small
I'm using a bench mounted vise and wood so I dont mar up the alloy. I'm preesing it in evenly, you can see how the bearing is cutting a grove all the way around the inside of mounting hole for the bearing.
Yes its the right bearing, I used the same bearings with no problem on the other upright/hub. I tried heating the hub and cooling the bearing. I guess I have to buy a new set[sm=thumbdown.gif] Its only a $75 fix.........stupid ********** ****** *** (Vent)
watch out for these..... I'm sure there are more of them, must be a manufacturer defect with a batch
RE: bad alloy front hub
i can see were the bearing has cut into the alloy - do you not know any one that can laith a bit of the alloy away so the bearing will fit - local metal works!!! or can you not send them back to the place you bought them.
WA
ORIGINAL: ibstar
send em back
a pain i know, looks like the final machining was missed
send em back
CA
ORIGINAL: hellya
I would if I could but it wasnt bought from a FG dealer........ I only paid $50 for the set now I knw why
ORIGINAL: ibstar
send em back
send em back
Tony
R/C Modelsport
